speed skier
- Mar 27, 2002
- 4
I have rewired my trailer, everything works great with my Crown Victoria. When I connect to my S10 Blazer the turn signal flash rate doubles like there is a ground problem. The flash rate is ok when using a test probe on the blazer's connector. I have connected a trailer tail light to the blazer connector and the flash rate immediately doubles. Brake and running lights are fine.<br /><br />During this process I also fixed the ground in the blazer which was not appearing on the connector. This had no effect.<br /><br />I believe the problem is in the blazer but I do not know where to look. Any ideas?
