Turn off engine, wiring diagram. Help!
Vagelis
Turn off engine wiring diagram. I bought a force 35hp 2stroke outboard rw504222 , and I change all cables. A day before I started the engine and it works perfectly but when I turn the key to “off” position the engine keeps running.. the wires that I have connect from my central switch are : start, pos+ , choke. I saw my friend’s other brand engine ( I think evinrude) that you have to ground a Black-yellow cable from the CDI but I have not this kind of cable to mine.. So how can i fix my wiring diagram to turn off my engine when I turn the key to off position? Thank you and sorry for my English!
jerryjerry05
Not positive but this might be the way the switch needs to be wired.
This a new switch? might be the wrong one?
Vagelis
It’s the same switch like before. But old cables are ruined and I start from the beginning.. I can’t understand your diagram. If you have a biggest diagram with switch and engine diagram how to turn off the motor I would be very grateful. Thanks a lot.
The Force power
I'm not if this for the right year of your motor, I hope this helpsCHRY35_50_80_84.gif
Vagelis
This is my motor... I cant find wiring diagram on google (with CDI) for force 35hp two stroke.. My god, every other brand engines have one cable from CDI “ engine off” to ground (-). This kind of motor has not this cable.. wtf....
The Force power
Follow the wire to the overheat sensor and tie into thatCHRY35_55_BattAlt.gif
jerryjerry05
rw504222 what's this # from?
The pictures show a 1987-93 FORCE!!
Post pics of the lower unit and the cowl.
We need to figure out the year for the right
wiring diagram.
They used the same parts on most smaller Forces,
The model# changes were usually small things like
a different connector or screw or nut/bolt.
F5H078 is the part# for your key switch.
CABLE, ELECTRIC CONTROL
F85843-1
The following link is for the wiring harness for your
motor.$75
Southcentral Outboards
4 North Main Street • Altamont, IL 62411
(618) 487-9499
Vagelis
wiring diagram.
F85843-1
motor.$75
(618) 487-9499
E4B764C2-D822-4089-9C02-8541BD4423AD.jpeg15C29D68-3758-48C1-A1B1-B90FA7485578.jpegE06C6536-D2ED-4D55-A55D-22268F57C64C.jpeg4E588A05-C21E-47BE-B3AB-BA48469229A6.jpeg3FD21C86-D298-4B97-9EE1-39D38C3F4C07.jpeg5A672A97-2717-409B-97B7-0656B372FE69.jpeg566454A6-C5C7-40A1-A50C-D4B04F8AB262.jpeg
jerryjerry05
The first pic has a foundry stamp. The circle
with the 87 in the middle. 1987 Looks like Dec.
or maybe January 1987??
The other # is a part#
The last pic: no such thing as EFI on any Force :)
You do a compression test? these 2cyl. can actually
run fairly well on just 1 cyl.
Any other ID#s were on the stbd. transom bracket,
looks like they've been gone a while??
Good luck.
Vagelis
Good luck.
I have taken out the engine to repair the boat and I have repositioned it again with two screws to do some work. Then they will be paint and everything will fit as it should. At the moment the problem I have, I mentioned it before. BTW thank you about your remarks.
