Tune up specs for 2.3 L OMC
Reel Poor
Its a 1990 (I think) 2.3L OMC without Enging ID decal. Drive ID plate indicates...Model # 985683...Engine 2.3L..Serial # T0664505<br /><br />This is a Ford base 2.3L with a Mallory point distributor<br /><br />I need dwell, ignition timing specs (base and total advance) and WOT RPMs.<br /><br />Thanks for any info.
marunr
Re: Tune up specs for 2.3 L OMC
I have a 1988 with the same setup.<br />Manual says:<br />dwell 36 degrees + or - 2 degrees<br />timing 10 degrees btdc<br />wot rpms 5200-5600<br />point gap .46mm, .018 in.<br />plug gap .9mm, .035 in.
