Hi
Trying to get some help getting a 1988 Merc V6 135 hp back in shape to my son?s speed boat. This question is from Sweden.
The first issue of this motor is the oil injection. It?s a lottery. The horn may sound or be silent when turning the key. If it sounds, it may be beep-beep-beep-beep or continuously beep-beep-beep-beep-beep-and so on. It may also be a constant beeeeeeeeeeeeeep like overheating. Temp is OK, motor runs OK with a slight bluish smoke. The motor does not have a oil tank, just the oil reservoir. We have been running the motor with a rigged sensor in the reservoir lid to prevent it from beeping and just filling/monitoring the reservoir. The beeping is really annoying. I consider removing the oil injection or disconnecting the horn and install a light signal instead. -What is your opinion? I would not like to pay for a full service as this will be more costly than the motor itself...in Sweden marine things are at least twice as expensive as in northern America.
The second issue is the serial number. The only thing I found was a stamped number in a freeze plug on top of the engine. B349117 implies that it is indeed a V6 135 hp from 1988, but since I haven?t found anything on the internet of this location of serial number, I am not sure. -Is this the correct serial number?
The third issue is that the vertical fin is damaged, some 1-1,5 inch is missing. -Do I dare to weld repair this (TIG) without the risk of distorting the shape of the lower gear housing? Is there any other way to fix this?
I have changed impeller, gear oil and spark plugs. Next stop thermostats.
The motor runs great, strong and stabile on idle rev.
Hoping for your help, regards
Hansen, Sweden
Hansen, Sweden
