Hi,<br />I have a 2004 25' Odessey tritoon with a 2004 Honda bf200 4 stroke. My recommended wot is suppose to be between 5000 and 6000 rpm's. I've tried three props, The original was a stainless Honda logo 15.25" dia 19 pitch with a wot of 4700 rpm's and 42 mph on GPS. The next prop was a stainless Solo 15.25 dia 17 pitch giving me a wot of 5800 and 33 mph. And finally Michigan Vortex aluminum 14.5 dia 19 pitch which gave me a wot of 5600 - 5700 rpm's and speed of 35 mph. All three props gave me good bow lift ( the two stainless were better for lift ), but the solo and vortek gave me alot more ventilation during trim and while slight turning trimmed. I know to lower trim during hard turns. The motors cavitation plate is level with the bottom of the toon but there is a 3/4" keel that extends below. The motor can't be lowered do to transom design.<br />My question is what prop do you guys recommend ( brand, # of blades and size )?<br />Also what would it hurt to run a rpm lower than recommende if it yeilds higher speeds? And would a hydrofoil help the ventilation problem?<br />Thanks Tom
