Trying to find carburetor rebuild kit
No4hMic
I can't for the life of me find a kit any website. I look at has so many kits and I don't know what I need please help!
Number stamped on the carb 61714136
It also says it's a 2 jet Rochester.
HT32BSX115
Howdy,
It might be helpful if you post your engine model number. (Since you're posting in the OMC forum you have an OMC engine/drive?)
You can view OMC part numbers at http://epc.brp.com/
Find your engine and find the OMC number for the carb repair kit. Use Google to find either the actual OMC kit or a Sierra replacement.
Regards,
Rick
No4hMic
I can't seam to find out what engine it is I believe it's a mercruser 3.0 here are some pictures
I appreciate you helping me, I wouldn't want to buy the wrong kit.
No4hMic
I just thought it would be helpful to give you some background
We purchased it about 4 years ago and when we took it out it stalled after returning to idle once warm and my dad left it sitting around
Fast forward about 3 months ago I took it upon myself to get it working put new fuel it and chained the fluids and took it out same problem with it stalling at idle once warm but runs great at cruising speed but hesitates at wot. When it would stall at idle I would adjust the mixture screws and it didn't affect much. So I would sit around till the engine cooled down and would run just fine at idle
southkogs
Sounds like you're over heating. That's an OMC Cobra from the looks of it. Not sure what year.
Have you changed the impeller?
Welcome aboard.
No4hMic
Thanks for your help I found out that I was looking at the wrong number the right number wasn't easily seen then befor rebuilding it I found out that the auto choke wasn't working and it was always closed
