rmiddleton
- Jan 29, 2011
- 7
The outboard is a 35el76g johnson out outboard that i purchased with a boat last year. I ran it alot last summer with no prolems. In fall it started to kind of bog when you idled up and then would kick in. It did this for multiple outings untill now all it will do is just bog along at 1/3 its normal speed. I can take the boat home and it will throttle up to full rpm it sounds in the tank but not on the water. Im an extreme novice with motors so ive done only small stuff.
Ive replaced both coils, installed a fuel filter after the gas tank, replaced gear oil in the lower unit and put on a new impellor.
