I have a 1990 Evinrude 9.9 (E10RESC) that I'm having a no-start problem with.
I've only owned this motor for a short time. The previous owner did a poor wiring job of removing the tiller kill switch and just keeping the one mounted to the engine next to the rope pull. It was no longer grounding out the powerpack when pressed so I pulled it out to resplice. Right now I have no kill switch whatsoever and the amphenol connector coming from the wiring harness is hanging free. However, now I have no spark, whereas previously the engine ran relatively well (you just couldn't stop it with the inoperable kill switch). It seems to be too much of a coincidence for my power pack or something else to have suddenly died after pulling the kill switch but I have cleaned up terminals (grounds, coil wires, spark plug wires) to no avail. This engine has the UFI so I can't easily get at the powerpack.
I can say that I have about 250 ohms from the secondary coil terminal (spark plugs) to ground on both coils. And nearly zero ohms from the primary to ground. I think that's about right (although the primary seems a little too low, I have seen 0.2-1 ohm as the recommended resistance). Any suggestions? Am I missing something really obvious? Thanks.
