cj8mule
- Apr 7, 2012
- 660
I'm working on a 1978 120hp 2.5L that is overheating while under load.
In the driveway:
I can run the engine on muffs all day long and temp will stay around 160 degrees.
In the lake:
Idleling in neutral, it will overheat.
Idleling while underway, it does not overheat. I can run it up to around 2000 rmps and it will not overheat. Above that, it will start to overheat.
The engine feels underpowered and will not run above 3100 rmps. It takes about 100 yards to get the boat to plane out. It also backfired a couple of times through the carb while at full throttle as I was trying to plane out.
Here's a little parts background:
New manifold, new waterpump, carb rebuild, and a fresh tuneup. I am pretty confident the boat is propped corectly.
I want to check the flow from the water intake hose. I thought I would recheck the timing. The distributer has a Pertronix ignitor conversion and I am not sure the weights are working.
If the weights are working, I should see the timing advance while rpms go up?
I need to check the engines re-circulating water pump?
ARRGGG.... my head hurts! I think there's more than one problem going on here. What would you check and in what order?
In the driveway:
In the lake:
