Troubleshoot alarm on 1993 75 hp mariner alarm
Den man
I tried disconnecting the blue wires from res and put a jumper between them going to sensor but nothing...
Texasmark
First determine which alarm it is; over heat or low oil. Disconnect the tan or tan blue stripe wire from the OT sensor and try it. Then go to the 2 light blue wires coming from the tank and disconnect at least one. If neither solves your problem you have a short somewhere in the wiring harness on the low side (ground) of the horn.
If OT get a new sensor mounted in the rear of the block. If oil, the magnet in the tank may have fallen off....seems to be a common reason for oil fails.
Mark
Beaux38
Den man, there is a slew of things that could cause this. Like Texasmark says, which alarm? Continuous beeeeeeeeep or Three intermittent Beep Beep Beep? Continuous is High Temp, Intermittent is Oil related. If it is the High temp, take the sender off, should be on the cylinder head and test it's continuity at ambient temp. Make sure its the right sender too, you may have a temp gauge sender on your head as well. Your high temp sender should have a tan wire with a blue stripe on it as mentioned on the previous post..It should not be a closed circuit. If it's not closed at ambient, put the sender in a pot with some water and heat it up on your stove, with a thermometer in the water. It should close the circuit at about 185deg F. and it should close suddenly, not gradually . If your sender checks out, your running hot. .If its oil related, Take your cap off and check the circuit with the float up and down. Should be a closed circuit with the float down and open with the float up. If that checks out, you should have a oil pump rotation sensor, no clue how to check that, it's tied to electronics to see if the motor is running to get permission to alarm. Could be a combination of things, but you should not be hot after a minute of running, unless maybe your oil pump isn't pumping oil, which I would think would be indicated by a lack of start-up smoke. If its Variable Rate Oil injection, your linkage could have somehow got out of sync too. Feed us some more info, would love to be able to help.
Den man
The alarm is constant as soon as you turn the key on. Tried disconnecting the blue wires from oil res but the alarm just keeps on going. Put a little jumper between the blue wires going to sensor but nothing. I have a multimeter but not sure where to start.
Beaux38
You have a short to ground some where on your High Temp circuit or your High temp sender has went to crap. Find your High temp sender, should be on your head with a black wire grounded to the block and a tan/blue stripe wire routed up to the buzzer under your console. Disconnect the black ground from the block, secure it away from any ground path and then turn the key on. If the alarm goes off again, remove the sender from it's pocket/well secure it from a grounding path and turn the key on again. If the alarm goes off now, you have a short to ground somewhere between your buzzer and the tan/blue stripe wire, most likely on the engine block somewhere, unless you have an aluminum boat. The continuous beep is not oil related.
If you jumpered the blue wires from the oil cap together, that should do nothing, if you jumper the wires that the oil cap wires quick connect to, it should close the circuit and give you an oil alarm, provided you don't already have a high temp alarm, which you do.
