Trouble with shifting back to neutral from full throttle
ivan555
Dear all,<br />I have recently changed the lower unit on my 1992 90HP force, and could not correctly adjust gear/throttle cables. The problem is when the boat is running in full throttle, it is impossible to pull it back to neutral. After killing the engine and shaking & twisting the cables I manage to click it back. Could you please advise how to adjust these two cables (they move in opposite directions, I am a little confused and don’t want to mess the setup completely). Also is there way and reason to grease those cables? Thanks a lot for you help,<br />Ivan
ivan555
Re: Trouble with shifting back to neutral from full throttle
any ideas...anyone?...
PuddleJumper
Did the problem first show up after you had the lower unit off?<br />Disconnect the cables from the motor and see if they are smooth and free. If not then get replacement cables. Trying to resurrect corroded cables is a bad idea from a safety standpoint.<br />Your control box may also be the culprit.You'll know when you have the cables off.
