TROUBLE WITH JOHNSON MOTOR 55 HORSE
SCOTT B
I RECENTLY TOOK OUT MY BOAT WHICH HAS A 1969 55 HORSE JOHNSON MOTOR #55esL69a. I COULD NOT GET IT TO START FOR AWHILE AND WHEN I FINALLY DID IT IDOLED SO LOW IT WOULD JUST DIE OUT. I TRIED THIS FOR A FEW MORE TIMES AND IT STILL DID IT. FINALLY MY BUDDY I WAS WITH DECIDED TO GIVE IT A LITTLE MORE GAS BY MANUALLY USING THE THROTTLE. WE THEN TRIED TO PUT IT IN GEAR BUT IT WOULD DIE. FINALLY WHEN WE DID GET IT TO GO THIS WAY THE THROTTLE CONTROL WAS NOT WORKING EVEN CLOSE TO IT'S CAPACITY. I'M NOT SURE IF IT'S THE CONTROLS OR POSSIBLY THE CARBUERATOR. I NEED SOME ADVISE ON WHAT TO DO. THANKS
Joe Reeves
Re: TROUBLE WITH JOHNSON MOTOR 55 HORSE
(Compression & Spark Test)<br />(J. Reeves)<br /> <br />1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.<br /> <br />2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!<br /> <br />If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark.<br /> <br />To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
jimmbo
Originally posted by Joe Reeves:<br />[To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem. [/QB]
Joe, you forgot this engine has a hydro-electric shift.
