Are the carburator blades supposed to be all the way open at WOT? mine are not, if i were to guess they are at about 60% throttle... now that i have fixed the tach im only getting 44-4600 rpms out of it. i tried to adjust the cable to open them up, and once i do this it will not idle lower than about 3k rpms. what do i need to do to get the blades open and the idle down to where it should be? btw i have it set now so that it idles where it should but only opens up to about 60% throttle when it should be WOT
Thanks,
David
Thanks,
David
