After removing the Lower unit and replacing the water pump, I'm having trouble reinstalling the lower unit .
The workshop manuals don't really go into any detail on refitting.
Q 1. Which gear should the lower unit be in when refitting, Neutral or Forward?
Q2. The shift rod has a off set section at top, should it face forward or aft on intallation?
I presume the gear shift is and up and down movement on the shift rod, instead of a turn like Mercs.
Q3. To adjust the shift rod length the manual mentions to attain the correct length screw it in fully and then unscew approx 6 rotations and check length to specs. It that done with the shift rod in the fully pushed down position? or other
