Trouble dropping drivegear to put in new impeller!
Soaringhigh
Hi I have a Evinrude 9.9 4 stroke 1995 E10FRELEOC. I am trying to put in a new impeller, I'VE read all the articles and have had it apart 6 times and can not find any joiner for the shift rod so I can drop the drive gear. I have put it in forward and backward and reach all the way up and down the rod and it's smooth. I think I need to unhook the shaft up by the linkage but I don't think the shaft will slide all the way through the top to bottom. Can anyone help me? I'm just a disabled veteran trying to get the wife back on the lake. I live N.W. Wisconsin thanks, I need to figure this out real soon.
F_R
Honorary Supreme Mariner
I confess I've never worked on one, but I believe you will find it disconnects up at the top end, in front of the powerhead, where the shifter shaft is.
oldboat1
should be at the top of the gearcase extension for the 20 or 25" shaft, whichever you have. Thinking maybe you haven't dropped the extension, just the gearcase assembly where the impeller is located.
Soaringhigh
Hey. Guy's thanks for the fast response! I dropped the extension first then shifted to reverse, I had plenty of room and ran my finger up and down at least 3" each way did the same in forward. In finding nothing like a 2 stroke I bolted it up and dropped the lower, did the same and the outcome was the same. I searched and searched for days, don't have money for a service manual that's why I'm here. By looking at the shift rod on Evinrude it looked like it had a linkage attachment on top. The question now is if I remove the shaft does it slide through the whole machine out of the bottom from the power head? Or what!
Thanks again.
oldboat1
not sure what you are saying -- found the shift link, yes? It's the brass link visible when you separate and lower the gearcase housing extension, if you have a long or extra long shaft. The gearcase and the housing extension detach the same way. When you find the shift rod link and detach the lower rod from the upper, you will drop the driveshaft and the lower shift rod down with the gearcase. The shaft will be long or extra long, depending on what you have (one piece). The lower shift rod will remain connected to the gearcase. Leave it in the configuration it was in. Don't turn it or try to unscrew it. And BTW, don't unscrew that phillips screw down on the bottom of the gearcase. There will be two large slotted screws that are there to drain and refill the gearcase with oil.
oldboat1
My apologies Soaring. I reread the parts blowup, and there does appear to be a full length shift shaft up the length of the leg, with attachment with a spring clip at at the shift handle linkage. Soo -- assuming you located the shift lever and linkage, and found the shaft connection, the shaft should drop like the driveshaft down with the gearcase housing, where it stays attached. (no more brass connector, and no upper and lower shift shafts). Might be an improvement even.
[see F_R had already described that......]
