Trottle cam adjustment Evin 15
enn
I am fine tuning my motor - but has no Workshopmanual (cant get one before holiday)<br /><br />Can any of your help me with the following:<br /><br />I need to know the correct adjustment for the trottle cam/carburator linkage on a 1991 Evinrude 15 hp.<br /><br />If anyone have a manual can you look it up - or scan the page in and e-mail it to me?
Marian
Re: Trottle cam adjustment Evin 15
Hello Enn,<br />I'm in the same holiday lock. You've been so kind to answer my post about Evinrude 4-hk. This engine has #B95721 which acc. to Lidingö Marin table should be '92 but I might be wrong. My Evinrude is 2-cyl, 2-stroke. short rigg motor. Have You any suggestion to breaker dist. I'll be much obliged. Sorry I can't help You with Your linkage problem. Regards, Marian
enn
Hello,<br /><br />I do not think your 4 hp 92 has any breakers - it should have electronic ignition. If it has breakers it shaoul be around 0,5 mm
Marian
Hello Enn. It has breakers and they look as an original configuration. Anyway, thanks a lot for Your suggestion. I wish You luck with Your trouble. I'll be running along to my "brygga" now.<br />Have a nice weekend, Marian
