Trophy 1802 engine size???
BIGGUN
I'm in the process of buying a 1994 Trophy 1802 walk around cuddy. No one can seem to tell me the motor's shaft length...20" or 25" or what the boat's capacity plate has listed as the largest outboard that I can install on it. I was hoping that someone here either owned one or knew this info and could let me know.<br /><br />Thanks in advance,<br />Kevin Miller
umblecumbuz
Re: Trophy 1802 engine size???
Try posting under Freshwater or Saltwater Fishing, Biggun.<br /><br />Might be more response there.
cuzner
My neighbour at the marina has that exact same boat.Its fitted with a 125 force I believe thats the origonal motor. If I run into him I,ll ask to see his plate, and shaft length :eek: <br /><br /> Jim
roscoe
Biggun, you posted in the right place, as this is a boat question.<br />If you cannot find the info elsewhere, measure the transom, top of mount area to the lowest part if the transom.<br />You can contact the Brunswick Boat Group (owner of Trophy) at Phone: (865) 582-2200<br /><br />They will have all the info you may want, be prepared to provide them with the hull id number.
BIGGUN
Thanks Jim, I hope you don't get into trouble asking him that. :) <br /><br />Kevin
