Trolling Motor
c.fish
Considering adding a small motor on to my boat so that I can maneuver in and out of tight spots and not worry about ruining the prop on the outdrive. I have a 1989 Larson 22' I/O, Thinking of using an electric motor. Any ideas of size needed. and mounting ideas?
JB
Re: Trolling Motor
To Electrics and Trollers.
c.fish
Re: Trolling Motor
I like the engine mount remote controll unit, but I do not understand where it gets boted to out drive.<br />If you have any experience let me know.<br />Thanks for the info.
OBJ
Re: Trolling Motor
Usually bolts to the anti-cavitation plate (right over the prop). Use the helm to steer the boat.
b.gagnon
Master Chief Petty Officer
Re: Trolling Motor
I have seen some installed on trim tabs..
rottenray6402
Ensign
Re: Trolling Motor
The problem with the ones bolted to the outdrive is you need to have the out drive down in order for the trolling motor to function. This is fine for deeper water but if you want this to get in and out of shallow bays I think you would be defeating the whole purpose of adding a trolling motor.
c.fish
Re: Trolling Motor
What type would mount to the trim tabs. Can they support it? What about steering?
