Trolling motor
cstoliker
I have a 1968 15' starcraft fiberglass boat with a 55hp Johnson. I use the boat for fishing a lot and want to buy an electric trolling motor for as cheap as possible. How well would a 30Lbs thrust motor due? Could it move the boat against light wind or waves? I just want to be able to move very short distances while fishing without having to constantly start and stop the main engine, or as a plain B in case the old Johnson was to quit while on the lake.
roscoe
Re: Trolling motor
It may do alright for you.<br />But shop around a little, you may be able to find a 36# or better, for about the same price. Some shops are starting to close out their inventory already.
JB
Re: Trolling motor
Moving to Electrics and Trollers
rverano
Re: Trolling motor
If you can, spend the extra bucks on a bigger motor. I had a 36lb thrust and now have a 42lb thrust and the difference is amazing. This is on a 16' aluminum.
