trolling motor
gcufisherman
I am a avid saltwater fisherman and i have a problem choosing witch trolling motor that i want for my 14' stumpknocker its a toss up between the Minnkota Riptide 55 pound trust 42" shaft that is composite or the motorguide varimax 55 pound trust 50" shaft that is anodized aluminum but they say its rated for saltwater but aluminum corrodes and i have heard that the minnkotas have lots of problems with them any input would be very helpful good or bad that's a lot of money to put down so i want to be on the best one.
Silvertip
Re: trolling motor
You were told Minnkotas have lots of problems!!!!! By whom?????? What sort of problems???????? Did you actually try to verify the claim by searching for reviews.
1980Galaxy
Re: trolling motor
+1.... I have actually heard more good things about minnkotas than anything.
G-Daddy
Re: trolling motor
I have had my Minn Kota RT55/S since 2004 and the only problem I have had is that the ribbon cable from the control board to the tiller control corroded from the salt. I had to replace the control board to fix it - but fix it I did. No complaints other than that. It is quite useful for controlled drifts with my 17' fiberglass center console boat.
duckland23
Re: trolling motor
Some of the older min-kota motors have problems with there sswitches going bad in them and minn kota wont have them anymore . You can use a newer style switch for them that they wont tell you . I had one fixed by a man in west allis wisconsin after all the dealers in illinois and south east wisconsin would not fix it even that they knew it could be done . My min-kota 65 had a bad switch in it and had to be replaced . I also read a post from a man that took the switch apart and cleaned it and it worked . I read that its a paid to do , but if you drill out the rivets and cut the glued plastic away and watch what your doing it can be done . Of course you need new rivets and some tape to take it apart . But most of what you need to do is clean and regrease the old switch and it should work fine . The old one will stick and not turn right , thats why you need to take it apart and clean it in the first place .
Star
Re: trolling motor
One more vote for Minn Kota, Fresh water only here, but a quality product. DO SPEND the EXTRA MONEY For I-Pilot what ever it costs it is worth it!!!!!!.
