trolling motor
94basscat
Bought boat over winter and owner had all 3 batteries out for winter. I got all wiring hooked up but having problems with the 2 trolling battery. TM is 12/24 volt and have played around with the wiring and can only get 12 or 24 volts to plug in front on the 12 volt slot on plug checking with volt meter. I can't get 24 volts to the 24 volt slot in plug up front. I have batteries wiring in series with + to - jumper. Front plug has 4 wires: red, white and two black. I didn't know if i could just run the TM with 24 volt thru the 12 volt slot, or how the 4 wires needed to be ran to get 24 volts on 24 v slot?
Silvertip
Honorary Supreme Mariner
Re: trolling motor
The solution to your problem is simple.
1) Remove the jumper (+ to -) between the two batteries. It is not needed in your system.
2) You need two wires (red & black) from one battery to the four terminal receptacle.
3) You need two wires (Orange & black) from the other battery to the four terminal receptacle.
4) You need to check the troller plug to see if it has a jumper inside. If it does, that is what does the 24 volt jumper that would normally be done at the battery.
5) If you have a switch panel up front with a 12/24/Run/Charge switch, that jumper may or may not be present. There are many wiring schemes but if that wiring looks like it hasn't been tampered with you can trace those wires to the receptacle to determine what's going on there.
6) You will have three wires going from the troller plug (red, orange, black, or red, white, black). Red-black = 24 volts and white black = 12 volts. You need to set the foot pedal switch accordingly of course.
