Frdtrtnfx4
- May 25, 2008
- 32
I just put a new minn kota 50lb thrust trolling motor on my boat. I was using the motor yesterday and it just stopped working. I checked all wires and everything looks ok. I checked the fuses and they are ok. I know its not the motor because, i took the plug and hooked it up to my freinds boat and it works fine. The only way i can get it to work on mine is, if i run a direct wire from the foot control back to the battery, bypassing the plug in the front. Is it possible that the female end of the plug in the front of the boat is burned up??? Its a 12v system, 16 ft lowe bass boat
