Re: Trolling Motor Recommendations
Your motor choices are essentially MotorGuide and MinnKota. There are a multitude of choices on either side which include electric steer (both foot pedal and wireless), cable steer, autopilot and built in locator transducer so the choice is really what works for you. I think the Terrova is over priced for the little benefit it has over the V2. As for shaft length, the best way to determine that is to launch the boat and measure the distance from the mounting surface on the boat to the water and then add one foot to 18 inches. I prefer the longer measurement to ensure the motor stays submerged in heavy swells. The key decision in this is how long your fishing day typically is and how you use the motor. If you slow troll for hours you would be advised to get a 24 volt motor which would put you in the 60 - 70 pound range. If you do mostly position fishing and use the big motor to get to a spot and just use the troller to move around that spot, you would probably get by with a 55# 12 volt V2 or similar. Only you can decide on these factors. If it were mine, a 20 foot boat would have a 24 volt motor.
