I'm looking to install a bow mounted trolling motor on 187OB. I would like to know if Hurricane has any recommendation on the position and installation of the motor.
Should it be installed going straight back from the center or at an angle?
Is there reinforcement under the deck for the installation or do I have to install a plywood or metal backing?
Do I need a special plate to clear the edge of boat?
I'm planning on using a Minn-kota removable plate to allow deck to be used as a swim platform when we aren't fishing.
Can anybody tell me if ski locker (which is not very long) on the 187/188 can accommodate a trolling motor with 54? or 60? shaft? I would like to store it there when not in use or traveling.
I know it's a lot of questions, so thank you for reading and any possible feedback.
