trolling motor props
redbuster
will a two blade give more thrust on my motor guide trolling motor better than the 3 or 4 blade style? i realize it may not be much but every little bit helps.<br /><br />thanks bert
Silvertip
Re: trolling motor props
No -- The more blades a prop has the better "bite" it has on the water and the more water it will push, thus more boat push. However, the motor must have sufficient power to turn the prop efficiently. With too little power, a three or four blade may hurt performance. Props are not terribly expensive so you might try experimenting. The true test however would be to install and ampmeter in the POS line to your motor. Run the existing prop and take an amp reading. If it draws significantly higher current with a three or four blade prop and you see very little performance improvement, but much higher current draw, go back to the original as all you've accomplished is to shorten the length of time the motor will run on a full battery charge. If performance increases with very little additional current draw, you could stay with the new prop.
b.gagnon
Master Chief Petty Officer
I have a 40lb minn kota with a two blade, and a motorguide with a three...The minn kota has more power! This is just my case I hope it helps.
b.gagnon
I forgot to add that the Motorguide is 46lbs...
redbuster
guy's thanks for the input. i am currently using a 2 blade prop and i still have the original 4 blade prop so i will just have to experiment with them and go from there.<br /><br />thanks again bert
ufm82
It's the same as an outboard prop- more blades bite better and run smoother but produce more drag while running. Two blades are good all around props but can be trouble in the weeds, especially on the MGs. Pitch and blade geometry have effects as well. However, since the options are severely limited as far as trolling motor props go, you'll just need to experiment. I had a 2 blade prop and a 3 blade prop for my first MG and hated the 3 blade Ninja- it was a weed gathering machine. The regular two blade actually did better in the slop than the Ninja did and I kept my speed up. The Ninja was a turd. I don't know about the current MG offerings as I went to the MK side long ago. <br /><br />UFM82
