vinnie1234
- Jul 7, 2014
- 161
I just got a 4hp Johnson seahorse and a kicker plate. I need to mount this setup to my 78 crestliner crusader. The problem I have is that the shaft length on the motor is a little short - and the stern protrudes at the top about 4 inches which obscures the control for the motor.
Before I start drilling holes in my hull, I want to find the best "happy medium" between having the cavitation plate of the motor below the hull and being able to access the controls when the motor is in the up position.
If I mount the motor so that the controls are accessible from inside the boat (up position) then the cavitation plate will be about 2.5 to 3.5" above the bottom of the hull when in the down position.
My thinking is that I can mount it in the higher position and trim the motor out from the hull and it should be fine.
Can anyone tell me how important it is to have the cav plate below the hull, or what I should do?
