Hello all,
I have my trolling motor connected to the same deep cycle battery as my fishfinder. The power leads for each device are ran along opposite sides of the boat, however there is common contact at the battery terminals. When I hit the pedal for the trolling motor, the inrush current causes a spike on the screen. Then during the operation of the trolling motor the fishfinder sees more fish than usual. A second but smaller spike occurs when the pedal is released.
I have rulled out cavitation and other forms of mechanical interferance due to the response time of the fishfinder screen and the time that the pedal is depressed. I think that this is entirely an electrical phenomenon caused by currents coming from the battery. Of course, I've been wrong many times before.
I've though about powering the fishfinder from my engine battery. I used another deep cycle w/ lots of cca for this purpose and it works great. However I fear two things:
1) That I may drain the battery so I cannot start the motor
2) While running the engine the rectifier will cause similar noise problems on the fishfinder. (this may be a scenario that I can live with since I mostly use the fishfinder when trolling)
Any ideas? (someone suggested placing a capacitor between the batt terminals to suppress the interferance). That may work since caps are an open circuit to dc and will soak up energy due to surges. The cap size will have to be strategically selected to be effective however.
