Re: trolling motor connection
My suggestion is to buy the matching four terminal plug. You then change wiring (DO NOT CUT OR REMOVE) to provide 24 volts directly to the connector. As pointed out, each battery currently has a pair of wires (Red and black from one battery, and orange with black/blue from the other). This creates two separate 12 volt paths to the connector. Without some sort of jumpering or switching, you could not get 24 volts. So here is a simple solution (provided someone has not already mucked with this wiring and created a "what the heck is this" rats nest).
1) For identification purposes, the battery that has the RED wire on the POS post is BATTERY #1. Leave that connection as it is but mark it +24 VOLTS. That will be the +24 VOLT connection at the receptacle when we are done.
NOTE: There should be a circuit breaker between the POSITIVE terminal and the RED wire. If you don't have one, you need to install one for safety purposes.
2) DISCONNECT (do not cut) the BLACK wire from BATTERY #1. Using tape, mark it -24 VOLTS. This wire will be the 24 volt GROUND connection at the receptacle.
3) DISCONNECT the ORANGE wire from BATTERY #2. It will be unused. Fold the wire end over and tape it up.
4) DISCONNECT the BLACK/BLUE wire from the NEG terminal on BATTERY #2. It will be unused. Fold the wire end over and tape it up.
5) Connect the BLACK wire you disconnected in step 2 to the NEG terminal on BATTERY #2.
6) Using a short piece of #6 wire, attach ring terminals to each end.
7) Connect one end of this "jumper" to the POS terminal on BATTERY #2 and the other end to the NEG terminal on BATTERY #1.
At this point you now have 24 volts to two terminals on the receptacle.
8) Connect the red and black wires from the motor to the new plug. Us ethe two terminals that match with the red and black terminals on the RECEPTACLE.
9) If you followed this "to the letter" Go fishing. If you didn't, you need to start over.
