Trolling motor batteries
SPORTSMAN68
Got a 112 pound thrust trolling motor---manual said to use 105 ah battery---it requires 3 batteries--so do I need each to be at least 105 ah ?
Silvertip
It is a 36 volt system so three 12 volt batteries wired in series are needed. Unless all three batteries are 105 Ahr as recommended, performance (run time) would be diminished if one or two of them were 80 Ahr respectively. The lesser rated batteries become the weak link in the chain so to speak.
Yes ...all 3 must be same. 105 is the minimum
SPORTSMAN68
CAN A SUPER CRANK HEAVY DUTY FLEET BATTERY BE USED IT HAS 120 AHR
SPORTSMAN68
not shouting---button sticking sorry----all they say is super crank heavy duty 120ahr---very heavy batteries---
if they are not deep cycle batteries, doesnt matter how heavy duty you think they are, you will kill them.
you dont use deep cycle batteries for cranking application
you dont use cranking batteries for deep cycle application
