trim worked now wont..
spinner7456
1986 suzuki 55hp with the power trim/tilt mounted on motor. The trim worked fine until i mounted this motor to my boat. it has power and makes noise like it should be working but wont lift the motor. thinking i should try and bleed the air out, but doesn't make sense that it worked and then didnt. any suggestions would be appreciated! thanks in advance!
99yam40
Re: trim worked now wont..
have you tried up and down? May have reversed the leads
spinner7456
I will have to look at it again.. just got this different motor mounted to the boat and found the trim not working. i will look at that... thank you!
