Trim wont go down...
ericp501
1996 boat has a mercruiser 4.3.. Goes up fine, but when I try to put it down it'll just "click, click" then sometimes it'll have a "humming" sound coming from it like it does when its going up, but doesn't move. Thoughts? hydrolic fluid low?
Don S
Re: Trim wont go down...
Look at it, we can't.
  • A1G2 Trim Troublelshooting.pdf
ericp501
I just quickly sprayed the whole thing down with engine degreaser and sprayed the electrical parts with intake cleaner, let it dry and it started working again.. Prob not the answer but hey if it works for now I'll take it.
TiredoleBoy
mine is the low pressure pump and was easily taken apart and fully cleaned every few years to keep corrosion from causing this.
ericp501
So I'm back to it not working. Doing the same thing.. up works fine, but down will "click" and I'll keep pressing it, then the motor will start to sound like its working but the trim still wont go down, I'll keep clicking and clicking and finally it'll start going down. It took almost 5 mins last time for it to finally go down. I'm not gonna take it back out again till I get this fixed. I have fluid (its a white pinkish color?).. and the up is working perfect. Its gotta be something with they hydraulic line right? Why else would the motor run but the trim not move?
strok351w
It sounds like you have a couple of problems. The white/pink color maybe water in the hydralic system and you also could have a bad relay for the pump motor or a bad connection.
ericp501
So why would the up work but the down not?
