Trim up on shifter not working
Leedanger
I swapped out a gimbal housing from a post 78' to a pre-78', the one I just put on has a linear style trim sender and the broken one had the senders on the side of the gimbal housing by the hinge pin. Since the swap the "bow up" function doesn't work, the "trailer" button does and so does the "bow down".
Anybody? Cheers.
Re: Trim up on shifter not working
Anybody? Cheers.
Ayuh,.... Ya didn't wire the "bow up" circuit through the limit switch...
Ya can wire it direct, but it won't stop at Trim, 'n will go to Tilt instead...
