Hi All,
Have a 2020 Tracker 175 Pro Team with a 75hp Mercury outboard. The trim down works fine, trim up does not work. I have tried replacing both (up and down) relays and no luck. The up trim relay clicks but the down relay does not click, even after trying two different new relays. I reversed the blue and green wires to check the trim motor that worked. I cleaned the contacts in the relay harness and still have an issue. I did a test with a multi meter with the relay removed and when your press the trim up the blue/white wire to the relay hardness gets power. Also made sure the relay is getting 12v power (red wire) and ground. While frustrated, I kept click the switch at the bow and for a moment it worked, tried the same thing at the throttle and on the motor. Every once and a while it engages for a second or two then nothing again. I'm at a loss and not sure what to do. Trying to schedule service but my local BP is backed up for weeks.
