Spurs, Your motor will have one or two solenoids, likely one, just for trim and tilt up. You should also have a trim limit switch mounted on the starboard trim bracket. Those break all the time. If you do not see hydraulic fluid (either 5W-30 motor oil or ATF) dripping, chances are the Teflon piston seal in one of the cylinders is leaking, causing the motor to lower.
If you have the three pushbutton PTT control panel, push the middle and top buttons together, and the motor should tilt. If not, you have some sort of wiring or electrical issue. You cannot bypass the solenoid on that model, except to tilt it up, on land. In the water, under power, the solenoid is necessary to provide the necessary current to trim up.
