trim tilt troubles force 125
boatinjeff
I recently blew one of the pilot valves out of my trim tilt unit I have a 1989 force 125 Can anyone out there help?
clanton
Re: trim tilt troubles force 125
Screw in or held in with snapring?
ridiver
Had SAME problem with 120 Force. First we purchased a similar part at the hardware store (check also automotive parts). We then machined that one to fit. Then we found a complete replacement setup at a local boat store. There are not many repair parts since they abandoned the strap design due to problems. <br /><br />f
clanton
I have an old pump and will give you the valve and snap ring, I will put a new seal in the valve,the new seal will prevent leak dowm. Now your turn look inside the hole that the valve come out of, you should see a valve with pointy tip on the end, try to remove this without damageing the tip. After you remove this valve you can remove the snapring on the other side and push out the other pilot valve and replace the seal inside the valve. If you dont have any leaks fill with ATF and you should have a good working system or you can UPS with return me the pump less motor and I will install the valve and seal in other side, Are you sure you have 1989 motor, the 89s hace screw in valve.
boatinjeff
Your right the boat is an 89, the motor is an 88.The model # on the engine is 1251E9B. The only # I could find on the power trim unit is HYM5001
clanton
The pilot valve ,shuttle valve, and snap-ring in the mail. Snap-ring bent probley need new one. I sent the shuttle valve, just in case it eas missing. The pilot valve has new seal inside.
boatinjeff
Thanks alot clanton, I've been looking everywhere for one. The guys at the boat shops around here said I would never find one! Right on :) :)
scubakidz
I WAS WONDERING IF THIS IS MY PROBLEM WITH BOTH MY ENGINES LEAKING DOWN, I HAVE 1990 FORCE 120'S THEY SLOWELY DROP DOWN, I HAVE A LARGE ALLEN SCREW ON THE PUMP HOUSING IS THIS WHERE THE VALVES ARE LOCATEDANY HELP WOULD BE GREAT,, IT WOULD BE NICE TO GET RID OF THE 2*4'S :rolleyes:
clanton
There should be 2 allen screws 180 degrees from each other. If you take them out the engine will drop, so block engine up or leave down.
scubakidz
clanton, I LOOKED AT THE TRIM PUMP AND THE 2ND ALLEN IS BETWEEN THE TRANSOM AND PUMP, TO GET VALVES OUT BOTH ALLENS HAVE TO COME OUT? ALSO I CALLED DEALER TO SEE IF THEY CAN ORDER VALVES FOR ME THEY SAID THEY ARE NOT AVAL. DO YOU KNOW OF A SOURCE TO GET THEM.. THANKS :)
clanton
There is 2 valves, you should replace seal in both sides. The part number is 829719 valve seat, you will need 2 of these. The seal is inside the valve. you get to the seal by prying off the end of the valve, with screwdriver and a rag wrapped round the tip,very carefuly. If tip does not move remove O-rings and heat in boiling water. You can call me 352-746-1953, I can explain this better if you have the valve in your hand. Dealers do not do this repair, most of them just sell the pump.
clanton
I gave you wrong pn, sorry bout that. The correct number is 820719 valve seat,
scubakidz
clanton thank you so much i have a feeling you saved me a ton of money, i will go to the boat shop and see if they will order this part for me again thanks a bunch,, if you are ever in myrtle beach area we have to do some fishing
