Trim tilt not going up
Dwells7583
Just put a 1999 ocean pro 130hp on my whaler. It has sat for 10 years but has under 20 hours on it.
The tilt motor runs but will not lift the engine up. You can move it by hand regardless of whether the release is tight or not.
I tried replacing the release valve screw. It did not help so i put the old one back in.
People are telling me its the relay but if it was, wouldnt the motor not run?
interalian
Sounds like you have no hydraulic fluid in the TnT. Release the manual valve, lift the motor up and put it on the trail lock. Take out the filler screw and check the oil. Not 100% sure what fluid yours takes (my older one uses ATF), so you need to confirm what fluid is needed if low.
interalian
If you're adding and it's not spilling out, you need to keep adding until it does spill out. Once there's enough in the system to start pumping, cycle it up and down a few times then check the level again, adding even more if required. Must be a lot of air in the system if it won't pump yet.
