Trim/Tilt Motor removal
FSUDTD
I have a 87 40hp Johnson that has the original TNT assembly with it. After several different diagnostic tests, I think it is time to replace the motor; my question is whether or not (or how) I can remove the motor itself without removing the resevoir and pump. Also, I was wondering if anyone had a parts cataloug that could tell me the part number of the motor and/or motor/resevoir combo so that i can price it. The mod # is J40TLCUD and the serial # is G7423433. Thanks for the responses!!<br />Brandon
DHPMARINE
Re: Trim/Tilt Motor removal
Is the pump located to the right (starboard)of the outboard?If so I usually remove the hydraulic lines,then pull the motor/resevoir/valve body as a unit.Then I remove the valve body and take the motor and resevoir to a starter repair shop and have them go thru it.Lots less than a new motor.Make sure you seal the lines from dirt,rain,etc.<br /><br />DHP
FSUDTD
Joe, I am not completely sure the electric motor is faulty to tell you the truth. Went out one day and when I hit the switch up or down all it did was click. Popped the top off of the electric motor to see that the braided wire attatching one of the brushes to the motor was corroded through at the contact point. I saudered that back, put the top back on and she was good to go... for a while. Went back out couple of trips later and nothing, not even a click. Popped the top again and saw that where the black wire connects to the inside top of the motor was halfway worn through as well as my saudering job on the brush was not going to last. I cannot get in to the close quarters to sufficiently sauder the wires; I think if I could get the a new brush saudered in correctly along with the black wire, i might be back in business. I would love to have your thoughts on the whole scenario, and thanks for your response.<br /><br />Also, DHP thank you; i called some electric motor shops in my area to see if they could rebuild the motor but to no avail. Did not think about a starter shop. Will definitely have to try what you talked about. thanks to both.
tomsinclair
FSUDTD's trim/tilt photos<br /><br />
47b5df27b3127cce9daed178bd9b00000026108BYtW7Vw3b4
<br />
47b5df27b3127cce9daedde33c3600000026108BYtW7Vw3b4
<br /><br />Just tryin' to be helpful.<br /><br />Posted by FSUDTD's dad and sometime fishin' buddy
Joe Reeves
Disregard my previous reply. Apparently I mistook the 40hp to be 140hp, therefore my outlook pertaining to removing the PTT electric motor was in error (and has been removed). However, what what you've had to say, I would feel that the PTT electric motor is due for replacement.
FSUDTD
Joe,<br />would you know offhand where i could track down the part number so that I can look into a relpacement. Also where I could find an aftermarket assembly at the least possible price. Thanks for the help!!<br />Brandon
llfish
Brandon, someplace on here there was a post that had an address to a web sight that you could e-mail questions like yours and get a response.<br />Also check out some salvage places and see if they have one on hand. Bought on off of E-Bay.<br /><br />Good luck
tomsinclair
Hey Brandon,<br /><br />I found these motors at various places that will fit your Johnson.<br /><br />Arco #6208<br />API #PT114N & #PT114R (R = remanufactured)<br />Sierra #18-6767 <br /> <br />Prices start about $285 ($215 for R)<br /><br />Good luck and tight lines.
