Hello All
I am new to boating, having purchased a (new to me) 1991 Maxum Cuddy with a 1989 Force 125HP outboard motor.
The trim/tilt motor assembly is leaking gear oil from, what I can observe, is the piston/rod (major) and also through the bolt where the oil is filled (minor).
Several times, I've been unable to lift the motor out of the water. But, after I top up the oil, the motor lifts right up. I am making people wait at the dock while I perform this quickly and so, feel a lot of pressure and don't like being a bad boating neighbour.
I am also afraid that I may burn the motor because this also happened while I was boating and I could tell that the trim/tilt was not responding.
Any advice or instruction on how I can stop this leak would be appreciated.
Thanks
Thanks
