Trim/Tilt installation HELP!!!
bubbaman
I had the seals go out in my trim/tilt unit on my 2002 Suzuki DF70, I had the hydraulic unit rebuilt and the guy hooked up his own motor to it to show me that it worked. When I got it to my house I bolted my motor to it, and nothing. The electric motor runs great, and will spin all day, but nothing is happening with the actual cylinder shaft? Am I doing something wrong? Any and all help is much appreciated!! -Jesse
jakedaawg
There is a little adapter key that goes between the motor and the pump. I would bet that this Did not get installed.
jakedaawg
It mates the two shafts. The electric motor shaft and the pump driven shaft.
bubbaman
Ahhh I'll bet youre right! Any idea what it is called or where I can buy one?!? Because I'm sure between my place, transport, and the guy who repaired it, it is long gone lol
jakedaawg
I can't find it on the parts blow up but it's there somewhere. A dealer can probably look it up.
99yam40
If you do not have it , call the people that did the work to see if they ended up with it or have one you can buy
