Trim/Tilt Hydraulic line inside replacement.
bltformula1980
I have a 1980 Formula One 16.75 Signa with a 470 3.7L 170hp motor. I have a leaking trim hose. How do you replace the line from the inside?
Grub54891
No Title
You can't. you have to remove the block on the outside of the drive, down under where the trim lines hook up from the ram's.,to access the fittings. here is a general picture to show where the hook in the block. and be Shure to use a new gasket on the block,or it will leak......don't ask me how I know that.
