Gilbert A.
- Aug 4, 2003
- 21
Buns: As a follow-up on the trim/tilt problem, if you check the wires coming from the tilt motor through the flexible casing back up to the solenoids, etc, you'll notice that one of them is a ground (attached in the area below the solenoids by a screw with a phillip head. Loosen this up and check it for a solid contact0, then re-tighten it. This worked for me when the problem of off and on functioning sneaked up on me once more, mostly because of infrequent use, I suppose.<br /><br />Good luck!<br />Gil
