Trim/tilt blows engine main fuse - Johnson 115hp Oceanrunner
norwarchipelago
Hi. The engine main fuse 20A blows when operating the trim/tilt switches on throttle/motor.
I have removed all wires to the pump, but the fuse still blows when pressing up or down.
I can't find any leak to ground from the relay box, and both relays are new. Anyhow, a bad relay shouldtent blow the fuse, should it?
Anyone who can give me help here?
F Smith
Chris1956
The wiring is likely shorted to ground somewhere in the engine harness, Look for melted wires on the engine harness.
If '96 and newer there are 2 connectors on port side of motor. Look there for melt, and then move to under dashboard wiring.
dingbat
If yours is like mine, neither switch, helm nor motor, is switching power.
The power comes directly off the starter solenoid, but you also have power feeding, thru a fuse, to the helm (via the engine harness) and trim switch on the motor.
I would start with the trim switch in the binnacle if you have one. I’ve had to replace mine twice
