I have a 19 ft. 1971 Sports-Craft cutty cab (C-Eagle)that has a 6ft. beam. I'm having two problems, the bow rides to high and I'm not able to trim it down with the outboard. Secondly there is a constant balancing act with the weight from left to right, moving gear, people, and switching gas tanks on and off trying to keep it "level". I'm thinking trim tabs would solve the left to right problem. I have seen the newer boats with extended transoms, are there "bolt on" transom extenders that would push the outboard back bringing down the bow?
