briggs09hp
- Jul 20, 2009
- 24
Hi,
I just bought my first boat and picked it up this weekend. It is a 1995 Sea Ray Signature 200 Cuddy. It has a Mercruiser 5.0 and Alpha 1 out drive. I thoroughly went through the boat I am very happy with it except for one problem.
On the shift/throttle control lever the trim down switch will trim the motor down, however the trim pump will keep running for as long as you hold the switch. The trim up switch does not work. The only way to trim the drive up is to press the trailer button. This will trim the drive up and the trim pump will stop. I read the service manual and it seems like it may be a faulty trim limit switch.
Also, the trim gauge does not move. It is stuck at the full up position. I am assuming the trim position sensor is used for the trim gauge, and the trim limit switch is used for the trim pump.
I test drove a boat last summer that had this same problem (1989 chaparral with a 3.0 and alpha 1), so I am wondering if this is common. Has anyone had this problem before? Any known fixes?
Thanks,
Matt
Thanks,
Matt
