A friend of mine recently replaced his propeller with a diferent pitch.<br /><br />Since the swap his boat has a tendency to pull to the right, and quite hard.<br /><br />I suggested he adjusted the trim tab.<br /><br />He discussed this with the mechanics at the marina and they said it is not the trim tab, but the stering which needs tightening, as they loosened it. As the steering resistance hasn't changed in my friends opinion, I still think it is the trim tab that requires adjusting. The pull is quite severe. Do you think this is a good prognosis? Can you get different size tabs if the adjustment is at maximum.<br /><br />Mechanics where I live in Oman are not the best in the world as you may see from other posts.<br /><br />Thanks
