Zackman
- Dec 3, 2005
- 376
I am new to boat ownership this season when I purchased a used 22 Cuddy with the Mercruiser 350 Mag and Bravo 3 drive. The top speed of the boat is in the 56 to 58 mph range, but I almost always cruise in the 30 to 35 mph range. I have never had any problems getting on plane or adjusting trim (outdrive only, the boat doesn't have trim tabs) to optimize speed vs engine rpm.
Yesterday we were out for the first time in cooler weather and I found myself cruising at the lowest comfortable speed which is about 24 to 25 mph. This was fine until a began making relatively sharp turns. The boat steering seemed to be heavy and did not respond well into the turns. I found myself have to turn the boat relatively hard and the boat began to list. If I remember correctly it would list in the direction I was turning (i.e. turning left the stern would list to the left).
Instead of changing the trim, because I was not sure if I was trimmed high or low, I just slowed down and actually came off plane.
My question (sorry about the long description) is given the type of listing I was experiencing should I trim down more and increase throttle slightly or am I trimmed down too much already.
Typically once I have reached the desired speed I trim up until the boat starts to porpoise and then trim down slightly.
