trim sensor?????
red423
1982 200 black max my original trim sensor has a stainlell clip that holds it on the mounting bracket, a. what is the pt number B. has it been upgraded to a newer part????????????
Faztbullet
The original number was 86485A5 and it is NLA and no aftermarket interchange avaiable......You can try sleezebay.
Dukedog
Just tha strap? You might try 88342. Doesn't show as NLA in hi-perf. parts but does in production parts. Strange??? Its cheap enough ta try and might work. Its used on early hi-perf.clamp for same thing as yours. Don't remember what yours looks like other than a 2 hole strap thingy.
red423
no not the strap I need the sensor, which is NLA, there has to be a mod for this as I am not the only person using an older merc engine.
