Wave34
- Oct 17, 2017
- 336
2004 Volvo Penta 5.7 Duoprop.
My trim indicator started to work intermittently, and now is showing UP all the time.
I disconnected the sensor behind the engine, and I measure somewhere between 10-200 ohms when the sensor was rotated, so the sensor is working.
I used a potentiometer connected to the wiring harness to simulate the sensor, just to make sure, and the gauge is not moving.
The black wire in the plug has continuity to ground.
The brown/white wire, has no continuity to the plug behind the gauge. (I tested all the pins)
Is it possible this wire is cut somewhere inside the hull? The wire goes inside a wire loom behind the engine, so tracing it is impossible without major surgery.
There is no brown/white wire in the gauge connector, only a brown one.
