Trim Sending unit
mjash
Sending unit on my boat is a sensor on the port cylinder. Resistance is very erratic in the cylinder...causes the gauge to jump all over the place...does anyone know of an aftermarket lever type sender I can mount to the bracket or something similar. OMC prices are outrageous for these sending units.
OBJ
Re: Trim Sending unit
Don't know of any Mark. I havn't ever tried before but if you can dig out the potting material around the reostat in the sending unit and get it out, you may find a replacement part at the local Radio Shack. You could fill the cavity up with silicon.<br /><br />Or...look around for a used one. Some boating mags have places listed that handle used parts. Being in Jersey, there may be one close. You might try TwinCity Outboards. Just do a search. They could have a used one there.
willamettejeff
I've purchased several through Ebay for 20 to 30 dollars with shipping this past winter. Both are new and function perfectly. One even included the gauge. Bought my tilt and trim unit there too.
dajohnson53
Panther Marine makes a "universal" sender and gauge. I am using one for a scissors type hydraulic jack lift I have - for which no OEM sender and position gauge is made. It works perfectly and is highly adaptable. Whether it would work on your engine I don't know, but it might be worth checking out. On the other hand, it isn't cheap either (>$100 US for sender and gauge, and I don't know if you can get sender separate - or if it would work with your OMC gauge).
OBJ
Thats something I didn't know D.. Thanks. The OEM sender is about $84 before tax and no gauge.
ratherBboating
I just took my sending unit apart yesterday. If you are a little technically knowledgeable you can do this. There is a potentiometer encased in silicone in the plastic housing. It is an Allen-Bradley water-tight pot. Allen-Bradley no longer makes this pot, but sold the copyright to another brand. I found one at Great Lakes Automation in Grand Rapids, Mi. Their number is 616-583-1564The part no. is 53C1-1K. You should be able to call your local A-B supplier, i'm sure these all come from the same place. The pot costs about $37. You could try getting a non water tight pot for about $5 and attempt to make it water tight. It is a 1K ohm, you only use about a 1/4 turn, so the fact that the new pot will have a "stopper" shouldn't matter (the existing one has no stopper, goes completely around) OMC made the sensor as water tight as they could and water still gets in there, so you mite get thru a season. You should check your wires out too, mine had some bare spots showing, so i plan to just run a wire thru the hole that the depth finder or speed sensor go thru ( a little red-neckish but chances are, the wire will never be seen when the boats in the water). The existing pot has 2 solder terminals, the new will have 3, just use an ohm meter to verify the direction matches between the pots and solder your wires on to one end post and the middle post, then solder a jumper from the unused side post to the middle post- this just insures that no sensor "floating" will occur. Water will find its way in there being that it's submerged, so i'd spend the money on the best silicone money can buy. Good Luck!
kcolney
ok this has been awhile but having the same problem the trim sender unit is water shot.
if this is such a problem and needs to be done each season is there a replacement part(s) or a aftermarket system that could replace this horrible design? these things are $90..... each id rather pay $150 or so and just change the whole system out to something that would work better.
anyone have info on this aftermarket or OEM part that could make this design over and done with? :confused:
