Re: Trim Sender
Thanks for all the advice, sorry I didn't get back to the board sooner. Apparently, I didn't find the sender on the gimbal ring axis because on some of these older models there is a linear-type sender located on the hydraulic sender inside the hydraulic piston assembly. No, I didn't figure it out, I called Mercruiser today. They faxed me a copy of the pertinent pages. Even the guys at the largest local marine shop didn't know. Wasn't in the Clymer manual, either.<br />I remember what you all said about the wiring too. Looked behind the gimbal ring toward the transom, and unfortunately, the wire has been cut.<br />Looks like a project AFTER this boating season!<br />Thanks all.
